1960 Decca DP547
1960 Decca DP547
Post: # 29294Post Hi-Fi-Mogul »
If anyone runs into one of these, I'm posting how to remove
the amplifier/speaker baffle for service.
After removing the changer, then some obvious wood
screws, I was still stumped on how to remove the amp.
Solution came when I had turned the player with the
front facing down. I noticed the baffle had moved
forward a bit.
So, I levered the four sides of the baffle with a putty
knife, and out it came !
Someone had jack-legged in a wrong values capacitor
can, so that all was cleaned up using a terminal strip
for new capacitors.
The original UA-8 BSR changer was a mess, so I used
an extra V-M 1210 changer, trimming its plinth a bit
to fit in the Decca cabinet.
I painted the front of the cabinet to a relatively close
color match.
Re: 1960 Decca DP547
Post: # 29295Post electra225 »
You have access to some really neat stuff, Mr. Mogul! What a cool little record player.....
The VM changer has GOT to be a major upgrade from the BSR, mess or no mess. ;) ;)
Post: # 29299Post William »
Nice job, Mr. Mogul. And the idea of painting the cabinet is something I would never have thought of.
Post: # 29308Post TC Chris »
How does it sound?
Post: # 29325Post Hi-Fi-Mogul »
TC Chris wrote: Thu Apr 16, 2026 1:46 am How does it sound?
Chris, the cartridge in the V-M is medium output,
so Vol must be at max.
Sound is about what I expect from a small speaker,
but nice and clear.
