Heathkit AA-14 troubleshooting
Post: # 24353Post TC Chris »
I'm trying to diagnose a funky channel in the amp. One channel sounds fine; the other only has any output when the volume is cranked up, and even then it is distorted. This is for a Heath AD-19 console, but the amp is the same as the AA-14. The output stage is complementary. I pulled both output transistors for each channel on a little RD transistor checker, and all 4 measure OK and virtually identical.
Our site won't allow pdf files but you can see the output stage at page 4 of this article:
https://www.w6ze.org/Heathkit/Heathkit_074_AA14.pdf
The problem is that I am measuring 38 VDC on the emitters on the bad channel. It's supposed to be 19 V, and it is in the good channel.
On the schematic in that article, the "A" figure in the upper right is the 38 V tap in the power supply. The only way I can see to have 38 V on the emitters is for electrolytic cap C27 to be short-circuited.
Does anybody have other ideas?
Re: Heathkit AA-14 troubleshooting
Post: # 24359Post electra225 »
As far as I know, any forum powered by PhpBB software won't allow PDF files to be posted on the forum. You can post them in Downloads so there can at least be some point of reference if that will help.
I am not as familiar with solid state equipment as I should be, but, from what I've read, one should always start by suspecting electrolytic coupling caps first. If you have a signal tracer, you can use it like you would on tube equipment to see where you are losing the signal. Good luck. :D
Post: # 24364Post TC Chris »
It's pretty clear that the problem is having 38 VDC where there should be 19 V. The working channel has all the voltages in their proper place.
So I did replace the electrolytic that, if it were shorted, would put about 38 V on the emitters. And that had no effect, so I put the original one back.
So now the only way there could be 38V on the emitters is if there were an internal short in Q13, the TA2577A silicon NPN output transistor. That tested fine out-of-circuit on my little Radio Shack transistor tester, but that device is doing its work with one or two AA batteries. Perhaps when 38V are applied to the collector, it's breaking down and putting 38 V at the emitter too. That would also explain the 38V appearing on the other transistor in the pair, a germanium 2N2148 PNP.
I will see if I can post to downloads. That is usually beyond my pay grade.
Post: # 24365Post TC Chris »
OK, I just uploaded the Heath AA-14 info to the downloads section (Up the down staircase?) under "amps and tuners."
In the schematic, the square box "A" in the upper right goes to the 38 VDC tap on the power supply. That puts 38 VDC on the NPN collector.
Conelrad
Post: # 24366Post Conelrad »
Since 19 is half of 38, I'm thinking it might be a problem with a bi-polar supply.
Complementary pairs can fail, causing the "neutral" not to hold the rails divided.
Lots of times this will occur in a driver stage, causing the output Xsister to run high current and add distortion.
If one has a dual-trace scope, it can be used to "see" distortion: Hook one scope input to the amp input. Hook the other to the amp output. Set the amp output scope range accordingly to get the two traces to coincide as close as possible to a single trace. Any derivation is distortion...
Post: # 24370Post TC Chris »
It's a B+ power supply referenced to chassis ground. The other channel (and preamp, and tuner) are all just fine, so the problem is somehow localized in one channel's output stage.
The full schematic that I have is a low-res download so I have been mostly looking at the clear but partial one in the article. I'll have to do some studying to see how the 19 VDC is developed at the emitters and maybe that will temm me how it has become 38 V.
Post: # 24387Post TC Chris »
I made contact with the guy who wrote the AA-14 article via his ham club and has has graciously agreed to advise on my problem. I sent him a reply detailing the issue and will wait to see what he suggests.
Post: # 24404Post Motorola minion »
Blow is JPG from amplifier text. This is a good example of solid state evolving as silicon devices are replacing germanium. This makes for tricky resistance and voltage checks. My first inclination would be to check the resistors including R69/71 (out of circuit) and that diode D1. If D1 or R69/71 were open, voltage at base would increase, biasing it on and conducting the 38v right through.
After everything switched over to silicon transistors, direct coupling circuits replaced capacitors, the advantage of this was better frequency response but again, troubleshooting became more difficult.
SS comp symm.jpg (127.75 KiB) Viewed 92043 times
One of the interesting features of this "hybrid" circuit is that it does not require a phase splitter (often interstage transformer) to drive the outputs at 180 degrees phase shift. One input from the preamp stage seems to simplify the diagnosis of a transistor biased on.
Good luck with the Author, maybe we can all learn something so THANKS for addressing this occasionally encountered solid state problem.
Post: # 24418Post TC Chris »
The guy who wrote that article did reply to my inquiry, and I have emailed back twice. The second was tonight after I went out and did some voltage checking. It is looking like the diode shown as D1 on his diagram (D101 &102 on the Heath schematic) or the driver transistor, Q11 on his, Q111/112 on Heath's. He has been very gracious about providing guidance.
I am lucky--all of the output transistors check OK out of circuit. They are hard to come by. And it is interest that the output pairs include one germanium and one silicon.
As I told him, this may be the on-ramp to diagnosing the funk channel on my old Heath AA-22. I was looking at my AA-22 file the other night and found the graphs for its performance at McIntosh clinics in 1968 and 1977. For you young folks, in those days, a guy named Dave O'Brien traveled around doing these amp clinics for Mac. He would test any make. He would measure distortion at rated power (or below, if necessary) across the audio spectrum and draw a graph. It was great advertising because in those days most equipment did not meet advertised specs, but McIntosh equipment always did (or he would repair it on the spot). My little Heath breezed through, performing within specs all the way both times. Yay for a rare company that wasn't just advertising puffery.
Post: # 24641Post TC Chris »
With the help of my online correspondent who worked on the AA-14, I have been moving ahead on mine (which is actually an AD-19, the console version). He sent me the circuit board diagrams, both sides, which are a huge help because the chassis is large and awkward and I was tired of flipping it back and forth all the time. Now I can just leave it and can locate the points where the components are soldered for voltage and resistance checking.
Indications are that it is the driver transistor that's bad, and the good news is, they are available and cheap. (Of course, the really good news is that the outputs are intact). Tomorrow I will pull the transistor and check it out of circuit but meanwhile I have ordered 2. Just in case....
Conelrad
Post: # 24642Post Conelrad »
I did mention the drivers could be at fault in many SS final problems.
DG
Post: # 24993Post TC Chris »
I've been frustrated by the Heath's failure to cooperate so I've been avoiding it. My internet helper on the project has emailed a helpful set of questions about voltages and resistances so tonight I wandered out to the shop, did some more testing, and emailed them off to the expert. I have a hunch that one of the output transistors tests good on the tiny Radio Shack tester (low voltage) but fails in circuit in the full 38 VDC. If so, it's the germanium half of the pair that's defunct (boo!).
Post: # 25342Post TC Chris »
My correspondent/guide in diagnosing this device has finally led me to the issue with my R channel. A 2200 ohm resistor had opened, applying way too much voltage on the driver and output transistors in that channel. Happily, all the rare devices (transistors) seem to be OK. I'll do some reassembly tomorrow night or next week. The advisor has the patience of Job, waiting for me to measure voltages & resistances and report back so he could make informed guesses about what was causing the way-off voltages.
I need to spend some time learning the basics of transistor circuitry. I cannot remember which symbols are the analogs for grid, cathode, plate so as to trace circuits.
Friday night, the Ford brake gods willing, I will drive 145 mi. SE to Bay City, where I grew up. The town has about 1% Irish-descent population, but it has had a big St. Patrick's Parade every year since 1954. The Chevy was in the parade 2x, back in the mid-60s. It is an old tradition to attend, and it has come to mark the beginning of the sailboat-maintenance season for me. My old boat was built in 1961 of fiberglass. In those days it was deemed suitable for plastic boats to have lots of varnished mahogany and spruce so they looked like real boats. Next summer will be the 58th season I've sailed the boat and the 57th time I've spent spring weekends in the boat barn, sanding and varnishing and preparing. The reward is the calls of "Hey, nice boat!" from other boaters. And, of course, the satisfaction of a job well done.
Post: # 25654Post TC Chris »
We figured the problem was solved when I replaced the open resistor. But nope, still way too much voltage on the outputs. So I replaced the driver transistor, which was the final possible culprit. That involved lots of contorted desoldering and resoldering. Plugged it in and hoped to see 19V. But NOOOOOO, still at 36V. Boo. I do commend my advisor for patience and trying to guide me through diagnosis from the other side of the continent.
Post: # 25659Post William »
I hate it when that happens. It is a good thing you have a helper and one of these days it will get sorted.
Post: # 25662Post electra225 »
To those of us who may be "transistor newbies", let me see if I have this right. The base would be like a grid in a tube, the emitter would be like the cathode, and the collector would be like the plate or anode in a tube. Is this close? :oops: :oops:
In the schematic Dave posted above, his post mentions that if R69/71 are there to bias Q13 and Q15 and to provide a load for Q11. If R69 and R71 and D1 were open, it could bias these transistors wide open. Can someone explain how this would happen? I don't understand what I'm seeing.... :oops: Looks to me like if the diode was open, it would kill the voltage to the base of Q15 at least....
Post: # 25670Post TC Chris »
The focus lately has been on those resistors--one was open, one drifted low to the edge of tolerance so I replaced it too. The driver transistor tested good in and out of circuit but last night I replaced it too. Very frustrating, especially when transistor circuit design is above my pay grade.
Thanks for the transistor-element primer. I'll draw a diagram and label the parts.
Post: # 25675Post TC Chris »
Success at last! Tonight I went out to the shop with a list of things to check. One was to check R 168, half of a voltage divider to set bias on Q112. I had replaced it because the original was open. It measured way high. So I looked to see if it looked burned. No. But wait, what's that 3rd color band? It should be red-red-red but damned if the 3rd one didn't look orange. The ohmmeter confirmed: 22K, not 2.2K. So I popped in a 2.2K and turned it on and checked the voltage and Bingo! Right one! And music came out of both channels!
Lesson: never underestimate my capacity for blunders.
The original driver, Q112, had an integrated heat sink. I had replaced the transistor when nothing else seemed to work and used a small clip on heat sink. After letting it run a while, I checked the temps with the IR thermometer. The other channel with its original heat sink was runnning about 104 deg. F. The replacement with its clip-on heat sink was steady at 88-90 deg. F.
Of course, this means more work. Installing the new speakers in the console, making backs for the enclosures. The original speakers were missing and the backs too.
Post: # 25744Post TC Chris »
Another update. After the receiver had been running for an hour or so, the driver transistor with its original heat sink measured about 20 deg. F hotter than the new one in the R channel with its aftermarket clip-on heat sink. But when I tested with my finger tip, the original transistor felt much cooler than its opposite-channel twin that measured cooler. That one was very hot to the touch even if it measured just 88 deg. F.
I've read that IR thermometers have some quirks and maybe that's why my finger and the digital readings did not agree. I am inclined to believe my finger tips.
So after thinking about it a while, and being a glutton for punishment anyway, I decided to replace the original driver, which tested good, and which had the integral original heat sink. The location was highly inconvenient for my desoldering tool and for access generally. Also, the printed circuit solder tabs had disappeared in the multiple desolder/solder operations. The replacement transistor had long tabs that I just bent over to make contact but the original had very short ones. I made up little loops with tails from fine wire to make the jump. Holding them in place while maneuvering solder and the pencil iron called for 3 hands. But eventually it was done and the device plays again.
Because this is a console, the FM antenna terminals and the record in/out jacks are mounted on a little remote plate that secures at the back of the cabinet. I flipped the chassis over and back about a gazillion times while testing and replacing components. The repeated motion caused the twinlead and one coax shield to break at the solder joints. Twinlead loves to do that. I desoldered the wires but my wire stripper has gone AWOL and I won't re-do the wires until it shows up.
But now the big problem is solved. I'll post a short YouTube video to prove victory soon.
Post: # 25757Post TC Chris »
Here's a short (< 3 min.) video of the device working. Yay!
https://youtu.be/rfXEUGwDqFk
