RCA Victor tuner chassis RC1192 FM-AM-FM/AM
Post: # 19510Post Motorola minion »
This far out chassis was used prior to a good plan to implement stereo multiplex, this the "living Stereo" monniker, referring more to the records versus a tuner with FM-AM simulcast. This is not HiFi by any means when one channel has FM R+L mono and the other is standard AM, via dedicated 12BE6-12BA6-19T8 signal path while FM is also active.
Issues with these besides silver mica disease is the 6E5 eye tube being dim to dead and wacky FM reception due to the German-made (via general instrument) 12DT8 tuner. I have covered the tuner problems by way of posts in RCA, Motorola and Magnavox forums. Zenith and others also used these 1960-64 just before solid-state tuners debuted in Magnavox.
The tired and rare 6E5 can be replaced 1 for 1 using a very-common test-equipment eye tube type 1629 provided the following modifications are made;
1. 6E5 uses 6-pin socket, 1629 is 8-pin octal, this is a no brainer, just consult a tube manual for the pinout. Target resistor is still 1 meg
2. 6E5 has 6.3 volt heater, 1629 has 12.6 volt heater, to boost and make it DC, use a doubler circuit formed by two 1N4005 and two 1000 mf caps.
Worked like new using AVC input voltages, closed fully only on strongest stations :geek: you saw it here first!
Re: RCA Victor tuner chassis RC1192 FM-AM-FM/AM
Post: # 19515Post hermitcrab »
I have done that mod as well... the 1629's are so much easier and cheaper to get, and that 1 meg is usually always way up in value
Post: # 19526Post electra225 »
I have a Lafayette signal generator much like that one. I still have a couple 6E5's on hand, but the time will come when I need to use something else. The 6E5 in the Imperial is essentially totally dead. I put it in new in 2014 and doesn't have a million hours on it. Magnavox should have made provisions to cut off the eye tube completely if you are not using the tuner. Running the eye tube all the time is an expensive extravagance. I reckon when our old stereos were built, 6E5's were still plentiful and cheap.... ;)
Post: # 19811Post Motorola minion »
electra225 wrote: ↑Sun Jan 28, 2024 3:34 pm I have a Lafayette signal generator much like that one.
I bought that from a guy from RI, whose Dad serviced electronics. The inside looks rather spartan with three tubes but it works great. These may have been kits also but it is very obviously Japanese-made.
Post: # 19815Post electra225 »
I got mine from my elmer, Lloyd, who had it rigged up as an AM transmitter.
sct4060
Junior Member
Post: # 22274Post sct4060 »
Hello,
My name is Scott and I am new to this forum.
I have been searching for this particular tuner to purchase and would like more information.
If I am in the wrong forum for "wanting to buy" please let me know.
Best,
Scott
Post: # 22276Post electra225 »
Welcome aboard, Scott! We are glad you joined us. Please feel free to jump right in and make yourself at home. I'll leave this post where it is. You might also advertise in the Classified board so your request may get more exposure. Welcome to the forum! :D :D
sct4060
Junior Member
Post: # 22278Post sct4060 »
electra225 wrote: ↑Sat Jul 20, 2024 6:42 pm Welcome aboard, Scott! We are glad you joined us. Please feel free to jump right in and make yourself at home. I'll leave this post where it is. You might also advertise in the Classified board so your request may get more exposure. Welcome to the forum! :D :D
Hello and Thank you!
Got it, I will post this on the classified section
sct4060
Junior Member
Post: # 22528Post sct4060 »
Motorola minion wrote: ↑Sun Jan 28, 2024 3:54 am This far out chassis was used prior to a good plan to implement stereo multiplex, this the "living Stereo" monniker, referring more to the records versus a tuner with FM-AM simulcast. This is not HiFi by any means when one channel has FM R+L mono and the other is standard AM, via dedicated 12BE6-12BA6-19T8 signal path while FM is also active.
Hello,
Just wanted to know if you are goint to keep this tuner.
I am looking to buy purchase one of these.
Scott
Post: # 22582Post Motorola minion »
The RC1192 was in three consoles I've had in my shop, two I have since sold. The next year (1962?) used a different style and tuning eye tube was the "bar type" 6FG6/EM84.
I may find one liberated from a console that can't be restored, there is a major swap meet next month in my area.
sct4060
Junior Member
Post: # 22584Post sct4060 »
Hello,
Oh that would be terrific.
I am looking for the RC1192 stereo tuner gif you find one.
Thank you!
