1965 Maestro Model 52
Post: # 19089Post Hi-Fi-Mogul »
Two nice young sisters brought their Grandma's Ward's
Airline console by for removal and service of the record changer.
Maestro is reported to have been a cheaper changer used in
lower end hi-fi's in the 60s.
But, this Airline radio/amp chassis is very well made.
I don't think the console was an inexpensive item.
It uses single 6BQ5 output tubes.
Two way woofer/tweeter with a crossover.
The cabinet is a lot of solid wood, in colonial style.
The Maestro has characteristics of both BSR and Garrard
mid-1960s units, but is U.S. made.
The Maestro uses a manual record size selector, with
all other functions automatic.
The Ronette 105 stereo cart has good output on each
channel, and the idler wheel still pulls through cycle.
I ordered a new idler from V of Music, though.
I did not have to do much dis-assembly for cleaning, with
exception of the motor.
The hardest task was removing the grease-locked record platter.
(another characteristic of BSR/Garrards, ha ha !)
I applied heat to the spindle for that.
Re: 1965 Maestro Model 52
Post: # 19092Post TC Chris »
Looks like a large power transformer for an 8-tube chassis.
Post: # 19094Post electra225 »
Did Wells-Gardner build that chassis? The whole thing looks well built. Never heard of a Maestro changer, but, then again, I live a sheltered life..... ;) :oops: :roll: :lol:
Post: # 19100Post William »
The changer looks like a VM on the top side but like Mr. Mogul states it's nowhere close on the bottom side. Quite simply looking actually.
Post: # 19123Post Hi-Fi-Mogul »
Question:
Is the metal plate the motor is attached to for
reducing any inductance or field created ?
It may just be engineered that way, but I've not
seen anything similar.
Post: # 19124Post electra225 »
It looks to me like they only use three bolts to mount the motor. Maybe that plate is there to stabilize the motor?
Post: # 19129Post William »
Do you have a photo of the topside of the changer, platter removed?
